Installation of MS8.12 in VS2008 (only 2005 possible)
Hello
I want to install Measurement Studio 8.12 to Visual Studio2008.
The Problem is, that installer says that there is no VS2005 installed.
Is there a trick to install it with only VS2008 installed?
Markus80
(6,474 Views)
Accepted by markus80
Refer to Using Measurement Studio 8.1.2 with Microsoft Visual Studio 2008 KB. As a side note, Measurement Studio 8.5 and later fully supports Visual Studio 2008.
Best Regards,
Jonathan N.
(6,468 Views)
Hi Jonathan
Thanks for your Help!
The Installation was successfull, but there are some Errors about the Licensing.
Error 2: Failed to perform action Licensing ...
this is at all componensts such as NationalInstruments.UI.WindowsForms
Markus80
(6,459 Views)
Hi Markus80,
You need to insert licensing yourself because 8.1.2 didn't fully support VS 2008. See the section "Using Measurement Studio 8.1.2 User Interface Controls and Analysis Libraries in Visual Studio 2008" in that link I sent earlier.
Best Regards,
Jonathan N.
(6,457 Views)
Hi Jonathan,
Now it works fine, but I don't really know why. I deinstalled the Measurementstudio after the Installation with the errors, then I reinstalled it and now it works.
Thank you very much for helping 🙂
Best Regards,
Markus80
(6,441 Views)
 我是一名measurement studio的学习者,但是现在没有这方面的教材,不知道从什么地方学起,现在是什么也不会。Smiley Sad有么有哪位高手有这方面的基础教材可以借来参考一下?谢谢啦,我现在急着用。关于涉及到所加控件的方法是在是一无所知……
(5,522 Views)
我是一名measurement studio 的初级学习者,现在对这方面的知识是一无所知,有没有哪位高手有这方面的教材可以借鉴一下……谢谢啦!!!
(5,522 Views)
