Network variable problem in 64 bit application
When running the software in 64 bit mode the ninetv.dll is not found by default settings. But if I copy ninetv.dll into the executable’s actual running directory the software complains that ninetv.dll is in a bad format.
In 32 bit mode it works always. Even if I do not copy ninetv.dll into the bin directory.
There are two pictures where you see loaded NI .NET assemblies. In the first in 32 bit mode and in the second in 64 bit mode. ninetv.dll is not shown.. Not sure how it is loaded.
nidlls_32bitmode.pngnidlls_32bitmode.pngnidlls_64bitmode.pngnidlls_64bitmode.pngBR, Ilkka
Message 21 of 34
(3,309 Views)
What you are missing is the 64-bit version of ninetv.dll
You should have two copies:
  • 32-bit: C:\Program Files (x86)\National Instruments\Shared\Network Variable\ninetv.dll
  • 64-bit: C:\Program Files\National Instruments\Shared\Network Variable\ninetv.dll
The easiest way to resolve this is to install the CVI 2015 Runtime - which will install both the 32 and 64-bit versions of the DLL, which our Measurement Studio DLL calls into.
Please try that and let us know.
Regards
Basel
Message 22 of 34
(3,301 Views)
I have two copies as in your message. But the copies seems to be exactly the same:
I will test the Labwindows runtime today evening in other computer and let you know about the result.
BR,
Ilkka
Message 23 of 34
(3,297 Views)
I installed the LabWindows runtime but it did not help anything. It is exactly as before.
BR,
Ilkka
Message 24 of 34
(3,291 Views)
Hey,
I will discuss this outcome with the team, and will write back to you soon.
Regards
Basel
Message 25 of 34
(3,284 Views)
Can you try the following:
- Explicitly set your project to a 64-bit build and copy over ninetv.dll from the 64-bit location and test this? So far we've been sticking to AnyCPU builds, which on a 64-bit OS should act like a 64-bit build but let's go ahead and cut this variable out.
- Can you run Dependency Walker on the 64-bit ninetv.dll to make sure it's not missing any of it's dependencies?
BR
Basel
Message 26 of 34
(3,262 Views)
This is the link to Dependency Walker:
http://www.dependencywalker.com/
Message 27 of 34
(3,249 Views)
I build the test applicaton in 64 bit mode but the result was the same.
After that I opened the ninetv.dll by the Depency Walker sw. The result is attached into this message.
BR,
Ilkka
Message 28 of 34
(3,244 Views)
This dependency walker log attached is for the 32-bit version of ninetv.dll, not the 64-bit version. If you are adding this version of ninetv.dll that is captured in the log to your project then that would be why its failing. You must use the version that is found at C:\Program Files not the version in C:\Program Files (x86).
Note: You also need to use the matching bitness of Dependency Walker, so use the 64-bit version to profile the 64-bit ninetv.dll
Finally, all these paths are assuming that you are installing software to the default locations, can we verify if this is true?
Message 29 of 34
(3,183 Views)
excuse of my late reply.  But it is the same 32 bit ninetv.dll in the Program Files folder in the following location
Please also note that usually 64 bit assemblies are in Program Files (x86) folder:
C:\Program Files (x86)\National Instruments\MeasurementStudioVS2012\DotNET\Assemblies (64-bit)\
C:\Program Files (x86)\National Instruments\MeasurementStudioVS2013\DotNET\Assemblies (64-bit)\
I have not found any 64 bit ninetv.dll from my Computer.
BR,
Ilkka
Message 30 of 34
(3,101 Views)
