System.IO.fileloadException: Could not load file or assembly NationalInstruments.Common, Version=13.0.40.188 The located assembly's manifest definition does not match the assembly reference.
For more detailed troubleshooting information, could you post the Fusion Log for the deployed project with TargetCPU set x86 and using the 32-bit NationalInstruments.Common DLL (or set to x64 with the 64-bit DLL - as long as matching bitness is forced) and containing the redirect configuration file? We've been discussing several variables and different error messages, so it would be helpful to control these variables and get a Fusion Log for detailed information about the assembly binding.
Taylor B.
Message 31 of 37
(4,775 Views)
Attaching fusion logs for posted example, targets x86 and x64.
Message 32 of 37
(4,766 Views)
I'm having trouble replying to this thread, but I wanted to point out that there is a file not found exception in "Fusion\Default\NiTdmsCommon.exe\NiTdmsCommon.resources, Version=1.0.0.0, Culture=en, PublicKeyToken=null.HTM".
The operation failed.
Bind result: hr = 0x80070002. The system cannot find the file specified.
Taylor B.
Message 34 of 37
(4,686 Views)
What is the error message that corresponds with the poted Fusion Logs?
Taylor B.
Message 35 of 37
(4,658 Views)
The previous reply with the attached images show the errors.
initial-error.png ‏28 KB
redirect-error.png ‏22 KB
Message 36 of 37
(4,625 Views)
If you are using C#, just at the reference there copy local set to true
Message 37 of 37
(1,868 Views)
