12-22-2014 10:14 AM
For more detailed troubleshooting information, could you post the Fusion Log for the deployed project with TargetCPU set x86 and using the 32-bit NationalInstruments.Common DLL (or set to x64 with the 64-bit DLL - as long as matching bitness is forced) and containing the redirect configuration file? We've been discussing several variables and different error messages, so it would be helpful to control these variables and get a Fusion Log for detailed information about the assembly binding.
12-23-2014 09:35 AM - edited 12-23-2014 09:43 AM
Attaching fusion logs for posted example, targets x86 and x64.
12-26-2014 11:35 AM
Thanks!
01-02-2015 02:32 PM
I'm having trouble replying to this thread, but I wanted to point out that there is a file not found exception in "Fusion\Default\NiTdmsCommon.exe\NiTdmsCommon.resources, Version=1.0.0.0, Culture=en, PublicKeyToken=null.HTM".
The operation failed. Bind result: hr = 0x80070002. The system cannot find the file specified.
01-05-2015 10:15 AM
What is the error message that corresponds with the poted Fusion Logs?
01-08-2015 12:49 PM
The previous reply with the attached images show the errors.
initial-error.png 28 KB
redirect-error.png 22 KB
12-19-2018 07:50 PM
If you are using C#, just at the reference there copy local set to true
