08-08-2005 02:15 AM
08-10-2005 08:03 AM
Hi there,
I have just tried this in LabVIEW with the nonlinear Lev-Mar fit function and I do get an error when the initial guess is too far off. ( error -20041). Also if I use another nonlinear fit function after the first one and use the best guess coefficients as the Initial guess input of the second one than I still get the same coefficients back like in the previous fit. So, in LabVIEW the algorithm works fine and I cannot reproduce the issues you seeing.
Can you send me an example that reproduces the issue in Measurement Studio (That's the soft you are using, right)?
Regards.
Joris V
