wpf axes label font size
Please is it possible to make the label size in a wpf image smaller or larger?
Thank you.
(5,707 Views)
Accepted by falopsy
If you want to set the size of all text elements in the graph, you can change the FontSize on the graph:
    <ni:Graph FontSize="22" ...>
If you want to set the size of the major division labels, you can change the FontSize on the LabelPresenter for the MajorDivisions:
    <ni:AxisDouble ...>
        <ni:AxisDouble.MajorDivisions>
            <ni:RangeLabeledDivisions>
                <ni:RangeLabeledDivisions.LabelPresenter>
                    <ni:GeneralValueFormatter FontSize="22" />
                </ni:RangeLabeledDivisions.LabelPresenter>
            </ni:RangeLabeledDivisions>
        </ni:AxisDouble.MajorDivisions>
    </ni:AxisDouble>
Or if you want to set the size of the axis label, you can use a custom LabelTemplate:
    <ni:AxisDouble Label="Label" ...>
        <ni:AxisDouble.LabelTemplate>
            <DataTemplate>
                <TextBlock Text="{Binding}" FontSize="22" />
            </DataTemplate>
        </ni:AxisDouble.LabelTemplate>
    </ni:AxisDouble>
~ Paul H
(5,700 Views)
Thank you very mush Paul.  That solved my problem.
(5,678 Views)
