wpf graph: fix width of vertical axis
How do I do that? Currently it's resized automatically to fit max tick label.
Message 1 of 9
(8,709 Views)
Hi EugeneM,
Can you post a picture of what you're seeing, and what you'd like instead? I'm not sure that I understand.
Thanks!
Alexandra
Message 2 of 9
(8,695 Views)
I need to fix width of selected area. Currently it depends on max length of numbers on the axis, e.g. if max value will be 1000.00 instead of 30.00 then axis will become wider...
Message 3 of 9
(8,691 Views)
Hi EugeneM,
According to this help page about the minimum width property, the graph will always expand to fit the largest value on the axis.
Alexandra
Message 4 of 9
(8,682 Views)
it seems to me that this reference is for WF graphs, not WPF, so it's not relevant
Message 5 of 9
(8,672 Views)
Hi EugeneM,
Whoops! The WPF also does not have an explicit property to set the width of the axis. You can change the visibility of the labels, and their orientation, which may help you with your space concerns.
What exactly are you trying to accomplish?
Alexandra
Message 6 of 9
(8,657 Views)
As Alex+ra mentioned, you can customize the LabelVisibility or LabelOrientation properties on the MajorDivisions of the vertical axis to change how the default labels are displayed. You can also customize the LabelPresenter, using a fixed-width format or using a custom formatter that provides fixed-width labels:
    <ni:AxisDouble Range="0,1000">
        <ni:AxisDouble.MajorDivisions>
            <ni:RangeLabeledDivisions LabelOrientation="Perpendicular" />
        </ni:AxisDouble.MajorDivisions>
    </ni:AxisDouble>
            <ni:RangeLabeledDivisions LabelPresenter="G1" />
    </ni:AxisDouble>
            <ni:RangeLabeledDivisions>
                <ni:RangeLabeledDivisions.LabelPresenter>
                    <ni:TemplateValuePresenter>
                        <ni:TemplateValuePresenter.Template>
                            <DataTemplate>
                                <Viewbox MaxWidth="16" StretchDirection="DownOnly">
                                    <TextBlock Text="{Binding}" />
                                </Viewbox>
                            </DataTemplate>
                        </ni:TemplateValuePresenter.Template>
                    </ni:TemplateValuePresenter>
                </ni:RangeLabeledDivisions.LabelPresenter>
            </ni:RangeLabeledDivisions>
    </ni:AxisDouble>
~ Paul H
Message 7 of 9
(8,645 Views)
Hi, Paul!
This is much better. Now the only question is how do I combine this with ValueFormatter override? LabelPresenter doesn't allow to have both GeneralValueFormatter and TemplateValuePresenter...
<!--ni:GeneralValueFormatter Format="0.00" /-->
<DataTemplate>
<Viewbox Width="41" Stretch="None" HorizontalAlignment="Right" Margin="0,0,5,0">
</Viewbox>
</DataTemplate>
Message 8 of 9
(8,642 Views)
Accepted by eugenem
I just used TemplateValuePresenter as an easy XAML-only example. When you define your own value formatter, you can return whatever UI element you want to display. For example, if you were deriving from GeneralValueFormatter, you could use code like below to wrap its visual in a Viewbox:
    protected override UIElement VisualizeCore<TData>( TData value, ValuePresenterArgs args, UIElement existingVisual ) {
        var viewbox =
               existingVisual as Viewbox
            ?? new Viewbox { MaxWidth = 16, StretchDirection = StretchDirection.DownOnly };
        viewbox.Child = base.VisualizeCore<TData>( value, args, viewbox.Child );
        return viewbox;
From your XAML snippet though, it looks like you just want to specify a .NET "0.00" format. In that case, you can use the StringFormat property provided by Binding:
    <TextBlock Text="{Binding StringFormat=0.00}" />
~ Paul H
Message 9 of 9
(8,638 Views)
