09-13-2016 12:24 PM
What is the recommended way to wrap DAQmx .net Async funtions into an iobservable?"
09-15-2016 09:47 AM
Shabnama,
This is Ali from National Instrument's applications engineering.
Would you mean something like this?
http://zone.ni.com/reference/en-XX/help/370473H-01/mstudiowebhelp/html/asynchreadwritedaqnet/
Additionally, could you explain a little bit about the usage of this wrap DAQmx function, it would be good to have a little background to recommend references.
09-15-2016 10:28 AM
Hi Ali,
Those are the available async functions in the NI API, we would like to have a wrapper around those functions to allow the consumption of the data through a Reactive Extensions (Rx) IObservable stream.
Shabnam
09-19-2016 12:03 PM
Shabnama,
Sorry for the late reply. I was doing a bit of research on the Reactive Extensions (Rx) IObservable platform.
Is there a specific DAQmx function you would like to utilize?
For example, are you doing a Read DAQmx wrapper and then asking Reactive to pull data as needed?
Feel free to send in psuedo code or a specific DAQmx function or list of functions that you are trying to use?
