I'm generating a continuous pulse train at CTR0 output, and I want to trigger data acquisition at the rising edge of the pulse.
I want to use the CWAI control of Measurement Studio, therefore the source signal for the trigger in the StartCondition has to be properely set. Do I have to connect any PFI pin (PFI0 for instance) to CTR0 out pin or I can directly use the latter as source signal? If this is the case, what is the name for it (GPCTR0_OUT, ......)?
Thank you for the help.
Luca Dore
