Measurement Studio for VC++
CWGraph color map
HI,
How to set the CWGraph color map using command line? I managed to set the color map using the CWGraph properties tab. However, if i use multi scheme color map, i need to code the color map using the command line. Any simple example?
thanks!
Message 1 of 1
(5,589 Views)
