Measurement Studio for VC++
I release a product in vc.net 2003, I added a NIGraph in my dialog. now ,the dlg can't show when the *.exe run on other's computer.Why??
I  have a project in VC.net 2003.
I  have created a dialog  MyDlg in my Proj.
I  have installed  measurement studio 7.0.1 in my computer.
I  have added NIGraph in my MyDlg.
Now, the *.exe working well on my computer.
I  copy the *.exe to other's computer,  the *.exe working normally  except the MyDlg can't show Window.
I think the matter is there is a lack of some *.dll.
But I don't know what??
Please help!
(5,794 Views)
Pls check if there is measurement studio support for VC.net 2003.
Install the measurement studio in your target PC, to see if the exe still can run or not.
(5,781 Views)
Make sure you installer includes the correct merge modules required for deploying the NIGraph. For a list of the merge modules, refer to the Measurement Studio help topic "Deploying Measurement Studio Windows applications". You can find this help integrated with the VS2003 help.
Bilal Durrani
NI
(5,772 Views)
Hi, Bilal Durrani
Thank you for your last answer!
Now , I find the Merge Modules folder under the path "C:\Program Files\Common Files\".
I try to add the needed merge modules in folder "New folder", I add the *.exe in the "New folder" , too.
I not packed, I only copy the "New folder" to a target computer,
Now, I try to running the program via double click the *.exe on the target computer. The problem is also as before.
(5,726 Views)
