Measurement Studio for VC++
how to give an path from LV to Visual Studio 2008 for working with DLL ?
Hi Guys,
I am working with an DLL that i write in Visual Studio 2008, where i open a file and make an average of 100 images but what if I want to choose A FILE from LV 2009 so that I don't have always to change these direction in the DLL???????????????
I think I can make these with an convert in LV, from path to string and from string to an BYte-array and then to convert in C back, but don't know how to convert back in C. The Dll works so far I give the byte-array to C and give the same byte-arrayback but that was only for test the prog, so how is it possible to convert these byte-array for use it in an "fopen" direction in C????
Wait for help or for other good advices how to give the path to C, Thanks !!!!!!!!!
Prog in C:
char path[52];
FILE *buffer;
buffer=fopen(path,"rb"); //that is the part where the byte-array has to be a string or an array of char ??????????
for(int i=0;i<52;i++)
 fread(&path,sizeof(short int),1,buffer);
(7,307 Views)
find attached a simple VI, which passes a path to a DLL.
The DLL opens a file, reads a text, closes the file and displays the result in a message pop up.
Find also attached the c-sources for the DLL.
How to run the program:
Copy the file “Test.txt” to your “C:” directory.
Open the LV Project and run the VI. That’s all.
There’s also a useful link available:
Writing Win32 Dynamic Link Libraries (DLLs) and Calling Them from LabVIEW
http://zone.ni.com/devzone/cda/tut/p/id/4877
Regards
Ulrich
AE NI-CER
(7,285 Views)
Hi UM,
first thanks for the answer but Ihave a problem to run this VI.I tried the VI but everytime I open the VI there is an error: The Procedurepoint"GetNumTreeCellItems" is not found in "cvirte.dll".
Do you know where the error is?  Do I have to add labview.lib to my project before and how do I do this ?
(7,281 Views)
Accepted by wweber_2
I created the DLL in NI LabWindows™/CVI.
That’s the reason, why you have to install the LabWindows/CVI Run-Time Engine engine.
You can download the CVI LabWindows/CVI Run-Time Engine from the NI-homepage:
http://joule.ni.com/nidu/cds/view/p/id/1525/lang/en
However, you can modify and recompile the code in your IDE (e.g. Visual Studio 2008).
Please check the properties of the call library function node in LabVIEW und the C-Code with his function parameters.
That’s the important thing. It’s not necessary to call the DLL.
Regards
Ulrich
(7,278 Views)
He Thanks for answer I've tried you way and it works  Smiley Wink
(7,273 Views)
