07-10-2008 06:29 AM
07-11-2008
06:32 AM
- last edited on
12-16-2025
11:52 AM
by
Content Cleaner
It seems that vs6 don't find the path to the tool or don't find the files for this tool. Therefore you should control the settings in vs6 and registry.
Best way is to test a default installation with vs6 and search for the path of the convert and add/remove wizard and then change it in pc with unknown error.
When error comes in default installation - then i need exactly you MStudio Version - in some versions you have patches (see links below)
http://digital.ni.com/public.nsf/allkb/C44974DB5CBA657C86256E9400183360?OpenDocument
http://digital.ni.com/public.nsf/allkb/879DED7B1EAFF49886256F0F0058A19E?OpenDocument
http://digital.ni.com/public.nsf/websearch/36C5E45E15A6862D86256B79005F89BB?OpenDocument
Perhaps adding the right path to VS 6 Settings solves the problem
http://digital.ni.com/public.nsf/allkb/905AEFF568F876B986256EDA00523D7E?OpenDocument
Can you attach here a screenshot from your error ? Does your default examples works in vs 6 with the changed path ?
07-11-2008 06:39 AM
07-11-2008 09:37 AM
07-11-2008
10:00 AM
- last edited on
12-16-2025
11:53 AM
by
Content Cleaner
Theses link describe using MStudio 8.x with Visual Studio 200x
Must check out if this version works with VS 6. Find here a link how to add the Wizard in VS 6
http://digital.ni.com/public.nsf/allkb/D3F8401C684B48D986256BDF00725A8A?OpenDocument
http://digital.ni.com/public.nsf/websearch/0CB6707522E92C958625689E0052BB77?OpenDocument
Perhaps you can add with these link the error link to wizard
Best Regards and nice Weekend
07-14-2008 01:28 AM
07-14-2008 03:34 AM
Ok - what happens when you install Visual Studio 6 on default directory ? Did you test it ?
Then we can say if problem is only because of pathes or when error still exists it could be a version problem.
Best Regards
09-11-2008 09:52 AM
I'm useing VC++ 6.0(SP6) and Measurement studio 8.1
but "Unknown message" dialog box still appears
Can someone help me to solve this problem, thanks
