Measurement Studio for VC++
monitoring pulse generation
Hi all,
I am using a USB-6210 card and measurement studio with VStudio2003. I would like to drive a stepper motor (which turns a miror in a spectrometer) by sending digital pulses to a motor driver. Using another channel on my card, i would also like to read a voltage (from an IR detector) every time i send 100 pulses to the stepper motor on the other channel. The purpose is to be able to log the voltage against the position of the motor.
I am not sure what the correct method is... I can think of different options :
  1. Use \National Instruments\MeasurementStudioVS2003\VCNET\Examples\DAQmx\Counter\Generate Pulse\GenDigPulse + incrementing a variable that counts each time i send a single pulse. When the variable reaches 100, i take a reading. This concept is simplistic, however with this method i am concerned about having to often start/stop the task.
  2. I have seen interesting examples in the following directories, using a continuous pulse train + counting digital events.
    1. \National Instruments\MeasurementStudioVS2003\VCNET\Examples\DAQmx\Counter\Generate Pulse\GenDigPulseTrain_Continuous
    2. \National Instruments\MeasurementStudioVS2003\VCNET\Examples\DAQmx\Counter\CountDigEvents\
    • How can i integrate these two examples to be able to count the pulses? Shall I just physically connect the counter pin and the pulse generation pin on the connector block of my card?
    • To decide whether the motor has arrived to the aimed position I could use the a "counting" class to drive (=start/stop) a "pulse generation" class ?
    • However the counting methods are driven by a Timing function (which runs every 50ms max), so i will always end up being slightly over positionned because of the lag time of the OnTime method? (i guess it doesnt really matters, as long as i know where i am)
  3. Use a finite pulse train. This imply using my two counters and then i would not be able to know where my motor is if the software was to end prematurely.
Does anyone know what is the right way to do this?
Laurent
(6,195 Views)
(6,184 Views)
