02-27-2002 08:36 AM
03-01-2002 10:09 AM
03-01-2002 12:00 PM
03-01-2002
12:37 PM
- last edited on
10-22-2025
04:47 PM
by
Content Cleaner
You may also want to investigate DataSocket for communication between the programs. Click here for more information.
From your comment, it seems you do not know much about data protection. I would suggest reading up on that material before you proceed with creating DLLs that multiple programs will use. There are many texts on this issue that can be found at many of the online book stores (amazon.com, bn.com, and so forth).
If all you are doing is passing information between the two programs, DataSocket is your best answer. You could also use tcp/ip.
03-02-2002 02:55 AM
