3 floor elevator
Hi to everyone!I want to build a 3 floor elevator simulation construction for a paper of mine.The plan is to be build like this.
pc->labview->modbus->rs232 converter->plc->elevator construction
I want to control the elevator from labview.Is there something wrong to the order?Do i miss something?Any information and links about same projects will be pracious,because it's the first time that i mess with all this stuff :-).Thank you all
(3,940 Views)
what you describe is a quite typical usecase. Here are some links that should help you to getting started with your Modbus communication:
Modbus LabVIEW Library
Creating Modbus I/O Servers (DSC Module)
Please note, that for the second option the LabVIEW DSC module is required.
I hope this helps,
Jochen Klier
(3,938 Views)
