4 channel independent motion controll adressing
I want to run four indepent motion/plc programs with each system using one axis and one analog output as a channel of the same motion controll card (PCI 7344)
Each indepentent system has its own bottons for starting different setions of a semi automated process and these processes are intependent in timing.
Can this be done with one 4 axis PCI 7344 NI motion card?
(2,966 Views)
The answer is short and simple: yes.
You only need to make sure that the controller is initialized before you start your four applications and that you don't share resources between the programs.
Jochen Klier
National Instruments Germany
(2,962 Views)
