-70119 limit switch error
My system includes 4 PCI-7358 cards, some brushless and brushed dc servo motors.
Mostly it works fine for a while but sometimes (randomly) some of the axes starts to throw modal error (-70119 limit switch error)
Limit switches are disabled from MAX and I also disabled them from software.
What could be the problem here? Could you help me please?
Kind regards...
(7,345 Views)
Hello serkanb,
I was able to find you a Knowledge Base Article that discusses error -70119. Usually the issue is from the wiring of the switch or trying to move further than the active limit switch. Since you have disabled the limit switches, I would check your wiring. Also, there was a known issue with this in NI-Motion 6.0 that was fixed in later versions. What version of NI-Motion are you using? Hope this helps!
Mychal F
(7,332 Views)
Actually there is no limit switches. There are two stoppers at both sides. My sytem runs a search alogrithm to find limits during initialization.
Here is my pseudo algorithm:
   // finding forward limit
   Go forward with slow speed.
   Repeat
      FollowingError  = ReadFollowingError()
   } Until   ( FollowingError  > Following_Error_Threshold. )
   Halt Stop
   Wait 100ms
   ForwardLimit = ReadEncoderPosition()
   Go reverse -1000 count  // to get rid of stiffness of string.
   // find reverse limit
   Go reverse with slow speed.
   Repeat
   } Until   ( FollowingError  > Following_Error_Threshold )
      Sometimes, not every run, system throws a modal error -70119 here!
   Go reverse 1000 count  // to get rid of stiffness of string.
   Halt Stop
   Wait 100ms
   ReverseLimit = ReadEncoderPosition()
   FindIndex();
  Kind regards...
(7,220 Views)
Hello serkanb,
Thanks for sending me the screen shot of your code! Could you also send me a screen shot of your limit switch settings in MAX (like the setting shown in the Knowledge Base article I linked you previously)?
Are you using an UMI? Also, what is currently wired to the limit switch pins on your controller?
I believe it may be a wiring issue since your code looks alright to me. Hope this helps and have a great day!
Mychal F
(7,194 Views)
