10-20-2011 07:10 AM
My system includes 4 PCI-7358 cards, some brushless and brushed dc servo motors.
Mostly it works fine for a while but sometimes (randomly) some of the axes starts to throw modal error (-70119 limit switch error)
Limit switches are disabled from MAX and I also disabled them from software.
What could be the problem here? Could you help me please?
Kind regards...
10-21-2011 08:48 AM
Hello serkanb,
I was able to find you a Knowledge Base Article that discusses error -70119. Usually the issue is from the wiring of the switch or trying to move further than the active limit switch. Since you have disabled the limit switches, I would check your wiring. Also, there was a known issue with this in NI-Motion 6.0 that was fixed in later versions. What version of NI-Motion are you using? Hope this helps!
Mychal F
10-23-2011 03:44 PM - edited 10-23-2011 03:50 PM
Actually there is no limit switches. There are two stoppers at both sides. My sytem runs a search alogrithm to find limits during initialization.
Here is my pseudo algorithm:
// finding forward limit
Go forward with slow speed.
Repeat
FollowingError = ReadFollowingError()
} Until ( FollowingError > Following_Error_Threshold. )
Halt Stop
Wait 100ms
ForwardLimit = ReadEncoderPosition()
Go reverse -1000 count // to get rid of stiffness of string.
// find reverse limit
Go reverse with slow speed.
Repeat
} Until ( FollowingError > Following_Error_Threshold )
Sometimes, not every run, system throws a modal error -70119 here!
Go reverse 1000 count // to get rid of stiffness of string.
Halt Stop
Wait 100ms
ReverseLimit = ReadEncoderPosition()
FindIndex();
Kind regards...
10-24-2011 11:10 AM
Hello serkanb,
Thanks for sending me the screen shot of your code! Could you also send me a screen shot of your limit switch settings in MAX (like the setting shown in the Knowledge Base article I linked you previously)?
Are you using an UMI? Also, what is currently wired to the limit switch pins on your controller?
I believe it may be a wiring issue since your code looks alright to me. Hope this helps and have a great day!
Mychal F
