06-27-2006 09:26 PM
07-02-2006 02:05 AM
Yoan,
Thanks for your post. To measure at a deterministic rate on the ADC, you may need to use a seperate DAQ card from your 7342 if it is being tasked to much from other processes. The only way to update and set velocity and acceleration modes on the board is to use the Load Velocity.flx and Load Accel.flx motion VIs in LabVIEW. If you require those to change every iteration of the loop, you will have to set them each time. On non-deterministic operating systems, you may not see the same performace on each iteration of the loops as Windows may task your processor to work on other threads during the same process.
Scott Savage
Applications Engineering
www.ni.com/support
07-03-2006 07:52 AM
