Should I be able to see the UMI-7764 on the configuration tree? I am using a PCI-7344 connected (via the motion control connector) to the UMI. The UMI is powered by an external power supply.
During the installation of the 7344, the manual said to expand the configuration tree. For some reason, I am not able to expand it. (It's there, but nothing happens when I click the +) . As a result, I can't gain access to the default settings etc.
Eventually I would like to use this setup to drive a Zeta stepper motor drive.
I am using Labview v 6i, and windowa 2000.
