How set parameters of AKD driver with LABVIEW ?
Hi
     I  am looking a simple example to set or read paramaters of AKD driver with Labview .
The AKD has ethernet communication and the control is analogue - AKD-P00306-NBAN-0000
I want to use Labview to read the same paramerters like Kollmorgen WorkBench
Thank you for  you help
(6,165 Views)
Hi k-usa,
We use Workbench to access these parameters, and unfortunately for many of them there isn't a way to access them in LabVIEW.  The manual for using the AKD with our C-Series modules (http://www.ni.com/pdf/manuals/375516b.pdf) specifies setting these parameters in Workbench for this reason.  I apologize that there isn't a way to access many of them in LabVIEW.
Julian R.
(6,102 Views)
Accepted by k-usa
Hi thank your for your help
  i just find a solution with TELNET protocol Smiley Wink
(6,097 Views)
Hi k-usa,
Interesting!  What is the solution you found?
Julian R.
(6,092 Views)
I use the telenet protocol with Labview API :
(6,090 Views)
