Is the LS485 temp controller still available?
I have a Flexmotion 6C PCI card and need the add-on cable that connects to it; in our application it's reffered to as a 'gear screw' connector. It connects to the card and provides what looks like a 25 pin male connection.
Any idea where I could get one of these? Also need an LS485 temperature controller (separate card) for the same application. This combination of cards is to control a pleater. Thanks.
Brad
(2,995 Views)
Brad,
It sounds like you have a custom cable that has been made for the Flexmotion 6C board. The standard way to connect to the 6C board is using a Flex100 Shielded Cable (P/N 777649-02) and using a UMI-Flex6 breakout (P/N 777627-06 - obsolete). The Flexmotion 6C board is an older motion board - if you need a new motion controller system, the 7340 series is a suggested upgrade (though it is not directly compatible with the pin-outs).
You can find the pin-out information for your 6C board in the following Flexmotion 6C Users Manual.
As for the LS485 temperature controller - I could not find any reference to this. Is this a National Instruments product?
I hope that helps - good luck with your project!
(2,991 Views)
