05-26-2005 02:29 PM
05-27-2005
12:16 PM
- last edited on
04-25-2024
03:19 PM
by
Content Cleaner
Brad,
It sounds like you have a custom cable that has been made for the Flexmotion 6C board. The standard way to connect to the 6C board is using a Flex100 Shielded Cable (P/N 777649-02) and using a UMI-Flex6 breakout (P/N 777627-06 - obsolete). The Flexmotion 6C board is an older motion board - if you need a new motion controller system, the 7340 series is a suggested upgrade (though it is not directly compatible with the pin-outs).
You can find the pin-out information for your 6C board in the following Flexmotion 6C Users Manual.
As for the LS485 temperature controller - I could not find any reference to this. Is this a National Instruments product?
I hope that helps - good luck with your project!
