Alright for the Universal Motion Interface (UMI-7764).
Firstly, the equipment I am focused on a is friction machine test and I would like to know if the static friction compensation (NI 7340 Series) is an important factor (probably for this kind of test)?
Then, the D550 or 650X0/X1 (Berger Lahr) are the steering cards for the 5-phase stepper motor (same manufacturer).
Here are the specifications:
- Operating voltage: 70...130 VDC
- Power input: max. 8A
- Adjustable achievement: max. 1000 W
- Rated current: 2...5 A/Phase
- Dynamic current increase by Boost I_Boost=100...190% In
max. 6A/Phase
- Engine line: Length <100m, cross section of a line >= 075 mm2
R_Lmax < 2 Ohm)
- Signal voltage for D 650.00/D 650.50: 20V...30V
D 650.01/D 650.51: 2,5V...5,25V
- Input currents: typ. 10 mA
- Signal frequency (pulse entrance): max. 100 kHz
- Relay contact exit change-over switch): 36 VDC / 30VAC,0,2 A
- Operating temperature: 0...55°C
- Storage temperature: 0...70°C
- Dampness class: "F" DIN 40400
- Mechanical dimensions:
- Weight: 1,3 kg
Moreover, I have an incremental linear encoder attached (Heidenhain LIDA 201) connected to adaptor EXE 6190B
for measuring the displacement of the stepper motor. The adaptor EXE 602, 605, 610 outputs a voltage between 1.4 and 4 volts, 1.4 and 4 volts, 0.4 and 1.7 volts, a frequency range from 0 to 50 Hz, and an operating voltage 5 volts +/-5% / 120 mA.
