Motion Control and Motor Drives
MAX never show "Axis is currently moving "
I´m trying to use the "Run/Stop Status" using flex_read_axis_status_rtn to determine if a particular axis is running.
So far I can´t get it working neither in my programm or testing using MAX/"Axis is currently moving" led.
I found this topic in forum "http://forums.ni.com/ni/board/message?board.id=240&message.id=1237&requireLogin=False", but it don´t explain why use velocity threshold or why the status is never set.
Can anyone provide an explanation?
Thanks!
(3,434 Views)
I donno why it does'nt appear but you can read velocity and check if the speed is less than equal to 2 rpm to find if the axis is moving. Although its not the best way to solve this problem, but may be I can help u if I get more info abt. your system
Giridhar Rajan
(3,414 Views)
Hi Giridhar,
Thanks for your reply. Your suggestion is exactly what I’m doing now. It’s also the suggestion in the link. But I really don’t feel comfortable implementing my program using something I don’t understand the reason, especially when there is other approach that is intended to do what I want and it doesn’t seems to work properly...
Perhaps you could help me with my other post (http://forums.ni.com/ni/board/message?board.id=240&message.id=4183#M4183) since I didn’t receive any answer from NI support.
Thank you very much Giridhar.
(3,402 Views)
