01-05-2012 03:00 AM
Now I am using NI9505 to control a motor. There is no requirement for the speed of the motor. What I need is only controlling the motor in two directions (backward and forward).
Could someone tell me what is the useage of the NI9505 encoder??? How to connect with motor if the motor don't have a DSUB?
If I just simply control the motor in two direction without other requirements. Then is that OK if I don't use the NI9505 encoder? Just connect Vsup, C, M+, M-, four wires and use LabVIEW to control M+ for forward move, M- for backward move?
01-05-2012 07:30 AM
Is there someone can help me? Thank you so so much!![]()
01-06-2012 05:01 AM
Hi Wenxi
Yes you can use the NI-9505 without using the encoder. This could i.e. be practical for a motor controller only using GPS.
Best Regards,
Anders Rohde
Applications Engineering
National Instruments Denmark
