Newbie Help: Single Axis Repeated Movement
Hi there - I have a (hopefully) simple question about creating a VI with NI Motion to help me control a stepper motor.
I have an NI 7334 Motion Controller box attached to a simple stepper motor. I've already used MAX to make sure that it works correctly, and I've already made a simple one-axis motion vi based off of the examples provided within the FlexMotion pack. My current predicament is in trying to code a VI that performs a cyclic movement (forward to max length, stop, reverse to minimum length). I can't seem to find a way to just make the motor go forward without any position input (essentially, I want three "operating states": on and extending, off, on and reversing). Right now, the only way I can do that is to have the stepper move to a position well outside its highest step.
I'm not a LabView expert, so any and all help on this will be appericated!
Thanks!
(3,929 Views)
Imran,
you should use the "Set Operation Mode.flx" vi to configure your axis to operate in Velocity Mode. In this mode you don't need to specify a target position and the axis will keep turning until you send the stop command.
I hope this helps,
Jochen Klier
(3,917 Views)
Thanks for the help Jochen, it worked out perfectly!
(3,812 Views)
