Rotary frequency Converter, input 3 phase 380V, 50Hz and output 3 phase 380V, 60 Hz
any one know how create the program for generator rotary frequency converter and who have the book about tha??
thanks.
(5,890 Views)
A rotary frequency converter is just a motor-generator set, and there is no programming associated with it.  What are you trying to do?
(5,884 Views)
i want to build a system to synchronize the generator, do you have a fundemental statement, or literature about that?
(5,881 Views)
Hi gurning,
If you could give us a little more complete description of the application you intend to create, we will be much better able to assist you. For example, what synchronization needs to take place? What is the need for the frequency change? Have you done any development toward the project so far?
Matt J - NI Tools Network
(5,866 Views)
