Rudundant positions in countour buffer
Is there any side effects writting redudant positions to a countour buffer? What PCI 7344 contour mode does if I write to the buffer a XY sequence like (0,0), (10,10), (10,10), (10,15), (10,15)?
Thanks.
(3,050 Views)
Telling the motor to move to the same point during a contour move effectively tells the motor to go to a zero velocity.  So for your example:
1. Start to (10,10) in 10 ms
2. Stay at (10,10) for 10 ms
3. (10,10) to (10,15) 10 ms
4. Stay at (10,15) for 10 ms
S. Arves S.
(3,045 Views)
