Motion Control and Motor Drives
Setting Position to Zero
I have a system that is controlling several stepper motors via network variables and I need to be able move the motors and then zero each axis position so that can use the new zero as the "home". I have tried just writing to the position variable but it did not stick. is there a method to do what I need? I do not have any encoders on the system just counting the steps.
(2,759 Views)
Accepted by LawrenceD
Are you able to use the "Reset Position" Express VI? (Assuming you're using SoftMotion Axes).
(2,710 Views)
