Target position error
I have some problem using an analog feedback PID to control a servo axis, both in MAX and in LabVIEW environment, on 7344 controller. The actual steady state axis position is at least 15-20% less than the target position. I have changed PID control loop parameters, but 15-20% difference is the best result. Do you have any idea how can this problem be resolved?
Thanks.
(3,639 Views)
Attached you can find a typical example of the system step response
(3,627 Views)
This looks like Ki = 0. Could you please provide your PID parameters?
Jochen Klier
National Instruments Germany
(3,623 Views)
For a tutorial about PID contol have a look to:
Classical PID Control
http://zone.ni.com/devzone/conceptd.nsf/webmain/F0A8687D6706719686256D6D005F9C56
Message Edited by Peter Schlosser on 03-31-2005 09:05 AM
Peter Griese
NI
(3,622 Views)
Please also have a look at this link. Here you find a less theoretical explanation of PID tuning based on the tuning features provided by MAX.
Jochen Klier
(3,613 Views)
Thank you very much for the exact answer, Jochen. The problem was in the absense of Ki and now the system can really achieve the target position.
(3,608 Views)
