Motion Control and Motor Drives
UMI-7774 5v power
 What is the current rating of the UMI-7774 internal 5Vdc power supply?  This is the power on pin 8 feedback connector.  User manual doesn't specify rating.  This is not the ISO power.  This relates to page 3-18 of manual.
(5,922 Views)
Accepted by dg_lbe
From the following PDF: http://www.ni.com/pdf/manuals/373359c.pdf: "Provides 1 A maximum output current, shared between Control connector pin 3, Feedback connector pins 4 and 8, and Trigger/Breakpoint connector pin 3."
It is on page 30, table 8.
Jim
(5,917 Views)
Thanks for your help. Believe Specifications page should be updated.
(5,906 Views)
By the by. Had been using doc. 373359b old revision.
(5,899 Views)
