how to send labview data to one of the usb ports of the system..?
i have a tracker data ie;roll, pitch and yaw data in the labview.. i need to send this data to one of the usb ports of the computer to control servo motors using parallax usb servo controller board.. aim of the project is to move two servo motors according to the head movements.. head movements are tracked using intersense itrax2 sensor.. plz help..
(6,394 Views)
What model Parallax board are you using?  The "Propeller" also has a serial port in, which would be much easier to use than USB from LabVIEW.
(6,383 Views)
am Propeller Servo Controller #28830...
(6,291 Views)
am using propeller Usb servo controller... i have got two vi's. one is to see the data from intersense itrax2 interial sensor and other is to control the propeller servo controller Usb.. please help me with the integration of this two vi's, so that i can use this interia sensor to control the two servo motors connected to pc through controller.. . plz help...
(6,289 Views)
