Motion Control and Motor Drives
how to simulate time step less than millisecond (ms)?
hi,
I am trying to simulate a data source with period less than 1 ms. and now I am using LabView 8.5.1, and I found "wait unitl next ms multiple", it seems the smallest time resolution is 1ms. How can I adjust to get less than 1 ms running?
Thanks...
(3,281 Views)
This question should be better posted to the LabVIEW forum instead of the Motion Control forum, but anyway.
The fastest timing source provided by Windows is 1 kHz That's the reason why you can't use a faster software timing in LabVIEW, but there are some options:
  • With LabVIEW RealTime you can use a 1 MHz timing source.
  • You can use an NI plugin board (not an USB device), e. g. an M Series board, to generate the timing for a timed loop.
I hope that helps,
Jochen Klier
(3,271 Views)
