umi-7774 power is not working ( request help urgently)
I have a umi-7774 and a pci-7340 controller, and they were working well, but suddenly when i try to turn on the umi-7774 again, the isolation power led was illuminated but the power led itself didn't illuminate, it only illuminate at the first contact of power supply, so i hope you can help me solve this problem as soon as possible.
(3,535 Views)
I would definately check the voltage at the V terminal of the 7774.  Does it still appear to have proper voltage coming into it?  You need to determine whether it is an external or internal fault.  Also, I am assuming this problem has caused the 7774 to stop functioning properly?
Jasper S
(3,516 Views)
Thank you for your reply, even it is late but anyway thank you, the problem was in my battery that supply power to UMI, since i go to the supplier office here, and the engineer there powers the UMI by a power supply with him, and the umi works properely, but what confuse me that when i measure the voltage out from my battery the voltage was 24V, and the current also was high, so i donnot know what is the problen with my battery
your sincerely,
ni-motion
(3,506 Views)
