I believe that I am setting the parameters correctly for a vector move, but the system does not move, so I must be doing something wrong.
The system
Two axes in the X direction with independent control (not slaved)
One Y axis.
System works perfectly for either X axis (both motor simultaneously moving) or Y axis moves.
System works perfectly for Multi-Start axis moves (coordinated start, but not coordinated end)
Vector #1 selected to be: X axis on X, Y axis on Y, X' axis on Z.
System does not start motion when Vector move is requested.
The system is in a clean room and heavily used for the code that is working, so I cannot have access whenever I want.
From looking at the NI manual, the only difference in the example shown from my code is that the vector space definition is made in-line with the move VIs
I initialize the vector at the start of the program.
I doubt that is the problem, but I will try that later. I would appreciate other ideas prior to testing later today.
Any thoughts or ideas are appreciated.
