10800 error generating continuous analog output with 6715
Good day.
Trying to generate any continuous analog output with my 6715 DAQ
gives a timeout error (10800). I have tried the basic examples from
LabView 7.0 (such as continuous sine generation). I also tried
the C examples that come with NI-DAQ (7.2). Same story.
The problem seem to exist only with "number of iterations" (AO_Control)
set to zero (iterate forever). If I request a finite number of cycles,
the things work.
Platform: T42 IBM laptop, WinXP SP2, LabView 7.0, NI-DAQ 7.2
Got really stuck here... And the local NI office has a corporate vacation
for a week!!
Will appreciate any help...
(2,912 Views)
Hello Genyap,
That error code you provided is a timeout warning rather than a fatal error. The following KnowledgeBase entry should provide you with more details on what to do: http://digital.ni.com/public.nsf/websearch/8DAA25834904A45186256C910070F7A8?OpenDocument .
Hope this helps.
(2,907 Views)
