-10805 overRunError
Is my DAQ card toast?
(2,952 Views)
it looks like, my ebay 6023 shows the same error on 4 channels and shows some scratches on the back
(2,952 Views)
Kurt,
Are you receiving this error in Measurement and Automation Explorer (MAX)? If you have not tried running the Test Panel from MAX, that would be my first suggestion. Did the device work previously? If you have another computer available, you may also want to consider testing the device in it. You can also run the Online E Series Diagnostic Utility (link available below). This utility is able to diagnose many hardware issues.
Spencer S.
(2,952 Views)
