32bit / 64bit PCI slots
Hi Dennis,
Thank you for the reply. I've downloaded NIDAQ 951mx and still have issues as it does not appear to install correctly and returns an error. It is the NIDAQ 951f2_downloader.exe. Can you verify this to be the correct driver to install and is it possible that traditional NIDAQ 7.4.4 must also be installed?
Message 11 of 15
(528 Views)
That's not the latest but it should still install on either Win7 or Vista 64-bit. What sort of error?
p.s. No, traditional DAQ is not supported on any 64-bit OS.
Message 12 of 15
(527 Views)
The install appeared to be good after a repair session through the Windows installer however the error that I am seeing after the DIO96 card is installed is "Windows could not load the installer for DAQDevice. Contact your hardware vendor for assistance. I do however want to point out that I am trying to run the driver with Windows XP. I noted that you said NIDAQ 9.5.1 should be OK with Vista or Windows, is this the wrong driver for XP?
Message 13 of 15
(522 Views)
There is no support for 64-bit Windows XP.
Message 14 of 15
(517 Views)
Ya - I just learned that Dennis. Thank you for your help. I'll be updating to Windows 7 (hopefully) and will let you know how I make out. Thanx again!
Message 15 of 15
(514 Views)
