08-20-2007 04:32 PM
Strain gauge calibration procedure has
failed. Ensure that the strain gauges are connected to all the
specified strain channels, the strain gauge connections are appropriate
for their bridge type configurations, the shunt resistor location is
specified correctly, and that your hardware jumpers (if any) are set up
correctly."
I can read a strain signal through MAX, but it just wont calibrate, and I get the 200045 error if I try to access the signal through SignalExpress or LabVIEW.
Thanks in advance,
Zach
10-17-2007 03:45 AM
10-17-2007 07:07 AM
10-31-2007 07:26 AM
11-01-2007 02:32 PM
11-02-2007 07:28 AM
Hani,
Thank you, I recieved an email from Ima with the fix for this problem. I am really glad that it has finally been resolved after a month of phone calls and sending modules back for repair. I am also happy to see that the fix has been posted on the NI website so that others should not have to go through the same pains that we did to get this issue resolved. Thanks again for your help.
Bryan K. Lilly
11-04-2007 07:12 PM
