Multifunction DAQ
Acquire two input signals (Analog) using DAQ USB 6363
Piezo1 connected to a0, Piezo2 connected to a1. How to get these two signals separately using (DAQassistant or piezo1 excitedpiezo1 excitedpiezo2 excitedpiezo2 excitedDAQmx) - DAQ USB 6363?
In the following figure, the front panel window shows two images - (piezo1 excited-it affects both graphs, piezo2 excited separately - it also affects both graphs), acquiring two piezo signals.
If piezo1 is excited, the signals are acquired in both graphs (Graph1 - piezo1, Graph2-piezo2) giving responses in both graphs.
If piezo2 is excited, the response signals are acquired in both graphs (Graph1 - piezo1, Graph2-piezo2), giving responses in both graphs.  We need to take a response separately using DAQ assistant or DAQmx.
How to solve this problem?
(1,728 Views)
Please share the original VI.
The issue seems electrical and not a software one, looks like the Ghosting effect expected in a Multiplexed AI, please refer to the below links for more details,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy6CAG&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P84RSAS&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9mKSAS&l=en-US
Santhosh
Soliton Technologies
(1,708 Views)
Thanks for the information, Mr. Santhosh.
The VI image is attached for your reference. In this LabVIEW block diagram, how can able to add a dummy channel in between ai0 and ai1 to avoid the ghosting effect.
Tell me your suggestions.
(1,683 Views)
