Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Adding an External Voltage
ASU
Member
02-14-2005
01:33 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
With the ER8/16 you can add an extenal power supply to drive bigger loads. Can this be done with any other DAQ brd,
particularly the 6025E?
0
Kudos
Message
1
of 2
(2,775 Views)
Reply
Re: Adding an External Voltage
AnujD
NI Employee (retired)
02-15-2005
09:44 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
No, this is not possible with the multifunction DAQ boards. If you need to drive bigger loads you would need to use a DIO board made for that purpose.
Anuj D.
0
Kudos
Message
2
of 2
(2,768 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
