Analog out triggered by PFI? (DAQmx C)
I'm trying to trigger a change in an analog output signal based on a digital input.
  1. AO = 1V
  2. DI Trigger rises
  3. Prepare AO for 2V
  4. DI Trigger falls=>AO goes to 2V
I have the digital trigger going into PFI1, which seems to work to trigger a continuous sine wave in MAX, but I'm unable to do it with the DAQmx C SDK.
I think it's a combination of DAQmxCfgSampClkTiming and/or DAQmxCfgDigEdgeStartTrig, but I'm unable to get it working.
Here's my code, simplified:
void setup(){
DAQmxCreateAOVoltageChan(handle,"Dev0/ao1","",-10.0,10.0,DAQmx_Val_Volts,"");
DAQmxCfgDigEdgeStartTrig (handle, "Dev0/PFI1", DAQmx_Val_Falling);
void changeVoltage(float v){
DAQmxWriteAnalogScalarF64(handle,true,100.0,Voltage,NULL);
The call to DAQmxWriteAnalogScalarF64 produces error -200262: An attempt has been made to configure a trigger without configuring the appropriate sample clock properties or when Sample Timing Type was set to On Demand.
So I added:
DAQmxCfgSampClkTiming(handle, NULL, 500000, DAQmx_Val_Falling, DAQmx_Val_HWTimedSinglePoint, 1);
but now DAQmxWriteAnalogScalarF64 produces error -89120: Source terminal to be routed could not be found on the device.
So what am I missing here?  Thanks for any and all help!
(3,809 Views)
I solved it.  I was able to accomplish this with:
void setup(){
   DAQmxCreateAOVoltageChan(handle,"Dev1/ao1","",-10.0,10.0,DAQmx_Val_Volts,"");
   DAQmxCfgSampClkTiming(handle, "PFI1", 1000, DAQmx_Val_Falling, DAQmx_Val_HWTimedSinglePoint, 1);
   DAQmxWriteAnalogScalarF64(handle,true,100.0,v,NULL);
I think the problem was referring to "Dev1/PFI1" instead of just "PFI1" - it doesn't know where to look when I give it the device name.
(3,798 Views)
Thanks Elleryjh for your post!! Smiley Happy
I was able to solve my problem with your indication.
Miko
(3,453 Views)
