Biginner: how to use a DAQ and Labview to control a valve and aquire signal from a level sensor?
I got BNC 2090 DAQ and labview 7.1 at hour university lab
i want to use them in a small project for paint mixing
i need to control the valves to open for a specified time
and to aquire a signal from the level sensors
can u explain generaly how to accomplish that?
Majd Badawi
(2,860 Views)
Hi Majd,
Your solution will depend on what type of DAQ device you are using. If it is possible, use the DAQmx driver and API to control the DAQ card. You can determine what DAQ device you have by opening Measurement & Automation Explorer and navigating to My System » Devices and Interfaces. Your card will then either appear under either NI-DAQmx Devices or Traditional NI-DAQ (Legacy) Devices. If you don’t see anything there, check the Windows Device Manager.
If you are using DAQmx, take a look at the following tutorial. It’s great for getting started with the API:
Developer Zone Tutorial: Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisiti...
If you have any more questions, please post what DAQ device you are using and what driver. Have a great day!
Ryan D.
District Sales Manager for Boston & Northern New England
(2,837 Views)
