08-26-2010 08:36 AM
I have a PXI4351 card to monitor the temperature with a PT100 sensor. I modified the driver from NI a bit to save the data and here everything works fine. But as soon as I want to build an executable from this vi I run into trouble. Now, the output of the "NI435x Read.vi" shows "Inf" and I can not read out any temperature values. I have not changed anything in the vi before compiling it. I also tried to implement some waiting times of a few hundred ms, without success. So, what does "Inf" mean? Really infinity or is it some form of error message I just don't understand?
Thx in advance
Greetings Dennis
08-27-2010 03:56 AM
Hello Dennis,
- Which LabVIEW version do you use for building this executable?
- Did you add the ni435xcm.dll to your project as this link describes? I would assume that this might be the cause for the behaviour you're experiencing.
- Another helpful link could this one be.
- Could youpost your project, so I could try to reproduce the behaviour on my side?
Andy
08-30-2010 08:53 AM
Hi Andy,
sorry it took me quite a bit to reply.
In the attachment you can find the small project. This is now a version without the driver itself (I tried to include also the driver in the project, but this resulted in a big mess). Nevertheless in the developer enviroment it should work, when the driver is installed in some standard directory.
Answering your questions:
1) I am using LabView 8.2 and I tried to run the executable on the same machine where I compiled it.
2) I also found the link just after I posted this thread, but unfortunately it does not help.
3) The driver I downloadad is for LV Version 7.1. As far as I understand the link, it was already solved there.
4) see attachment
Thanks again
Greetings Dennis
09-02-2010 05:19 AM
Hi Dennis,
I looked at your Project and found a few inconsistences that might cause this problem:
-it would be much more efficient if you open and close your file once beyond your while loop
-insert a timing in your while loop to save systemresources elsewise your PC would execute the while loop as fast as possible and ousted therefore other processes.
-at least, it would be much more easier to debugg your programm if you merge all errorlines together and insert a errordialogbox at the end of the line.
Best regards and good luck!
09-02-2010 08:08 AM
Hi again 🙂
I tried to build an executable of your project and everything works fine.
Other than you did I used only unmodified driver from NI. Therto I want to ask you if you saved the changed driver VIs at the same location with the same name?
Respectively could you send me the modified driver too.
have a nice day!
Andy
09-09-2010 07:24 AM
so finally I solved the problem, but I don´t know why ...
I started from scratch and installed the driver again, wrote my vi again and compiled it again (this time I was more careful with the naming and the location of the files, so I am sure this is all fine now), with the same result: I could not read out the temperature sensor with the executable. And now comes the funny part: I am using a current of 1mA, so in my Vi I executed the SetCurrentSource Sub-Vi with the parameter 1mA. But if I set this to 25uA everything is fine and the executable is working. The wrong factor of 40 I can now easily compensate later. But it is strange, and I don´t understand why this one parameter has this effect.
Thanks again for your help
Greetings Dennis
