Multifunction DAQ
CONNECTING 80 CHANNELS WITH PCI 6255
HELLO
I want to connect all 80 single ended inputs with PCI 6255 DAQ. Is the two connector blocks recommended by NI (SCC-68 for connector 0 and SCB-68 for connector 1) are enough for connecting all 80 channels or i have to use some extra connector blocks?
(3,379 Views)
It is enough
But, do buy the respective Connecting Cables, along with the connector blocks Smiley Wink
(3,377 Views)
Greetings Asim,
To elaborate further on devchander's comment, there are specific cables to be used for Connector 0 and Connector 1, namely the SHC68-68-EPM and the SHC68-68 respectively. As for the screw terminal connector blocks, you can use the SCC-68 or SCB-68 for Connector 0, and we only recommend the SCB-68 for Connector 1.
Please let us know if you have any further questions and/or have any feedback on our products. Hope this helps.
Nathan Yang | Data Acquisition Product Manager | National Instruments
(3,363 Views)
