03-14-2007 10:13 PM
03-15-2007
10:42 PM
- last edited on
02-10-2025
11:50 AM
by
Content Cleaner
Check out the NI PXI-4072 FlexDMM and LCR Meter. This DMM has a maximum range of -10000 uF to 10000 uF with a range sensitivity of 1uF. The minimum range is -300 pF to 300 pF with a range sensitivity of 0.05 pF.
03-16-2007 10:12 AM - edited 03-16-2007 10:12 AM
Elijah:
I'm a bit confused by the capacitance ranges you noted. What is negative capacitance?
Edit:
Looking at the specs in the link you posted I also see negative resistance ranges too. I think there are errors in the listed specs.
Message Edited by AnalogKid2DigitalMan on 03-16-2007 08:14 AM
Edit (2)
And negative inductance ranges shown too.
Message Edited by AnalogKid2DigitalMan on 03-16-2007 08:15 AM
03-19-2007
02:53 PM
- last edited on
02-10-2025
11:51 AM
by
Content Cleaner
I recommend consulting the detailed specifications for a more thurough explination of the specifications. Open the PDF here
You'll see that it does not have negative values listed in the specifications.
03-27-2007 12:00 PM
Elijah:
Thanks for correcting the specs shown on the link![]()
-AK2DM
