Capacitance, resistance and Voltage measurment.
I am looking for the best fit from NI to measure capacitance(in the Nano farad range), voltage, current and rise/fall time of a circuit (from 0.05 to 30 Microsecond range at 12 VDC).  The project will be using LabView, but I am unsure as to what hardware would be the best fit for cost and functionality.
(3,558 Views)
Check out the NI PXI-4072 FlexDMM and LCR Meter.  This DMM has a maximum range of -10000 uF to 10000 uF with a range sensitivity of 1uF.  The minimum range is -300 pF to 300 pF with a range sensitivity of 0.05 pF.
Elijah Kerry
NI Director, Software Community
(3,543 Views)
Elijah:
I'm a bit confused by the capacitance ranges you noted. What is negative capacitance?
Edit:
Looking at the specs in the link you posted I also see negative resistance ranges too. I think there are errors in the listed specs.
Message Edited by AnalogKid2DigitalMan on 03-16-2007 08:14 AM
Edit (2)
And negative inductance ranges shown too.
Message Edited by AnalogKid2DigitalMan on 03-16-2007 08:15 AM
(3,538 Views)
I recommend consulting the detailed specifications for a more thurough explination of the specifications.  Open the PDF here
You'll see that it does not have negative values listed in the specifications.
Elijah Kerry
(3,504 Views)
Elijah:
Thanks for correcting the specs shown on the linkhappy smiley
-AK2DM
(3,450 Views)
