01-21-2011 04:42 AM
I'm using LabWindows/CVI and am attempting to output a DC voltage (using regeneration) to a PXI-6723 output. The code (very cutdown version) I have written is as follows:
#define NUM_SAMPLES_TO_WRITE 2
#define ANALOGUE_SAMPLING_RATE = 200;
float64 data[NUM_SAMPLES_TO_WRITE] = {0.0};
DAQmxCreateTask("",&task_handle);
DAQmxCreateAOVoltageChan(task_handle,channel_id, >name,minimum,maximum,DAQmx_Val_Volts, NULL);
DAQmxSetWriteRegenMode(task_handle, DAQmx_Val_AllowRegen);
DAQmxCfgSampClkTiming(task_handle, NULL, ANALOGUE_SAMPLING_RATE, DAQmx_Val_Rising, DAQmx_Val_ContSamps, NUM_SAMPLES_TO_WRITE);
DAQmxWriteAnalogF64(task_handle,NUM_SAMPLES_TO_WRITE,1,10.0,DAQmx_Val_GroupByChannel,&data[0],&no_samples, NULL);
data[0] = 5.0;
data[1] = 5.0;
DAQmxStopTask(task_handle);
The above code works fine but I am unsure as to why I have to stop the task before writing my new data using the DAQmxWriteAnalogF64 function. If I don't stop the task, the write function completes successfully but the outputs don't change. Am I missing something?
Martin
Solved! Go to Solution.
01-24-2011 08:34 AM - edited 01-24-2011 08:35 AM
Hey Martin,
You must ensure that the DAQmxWriteAnalogueF64(...) is in a loop during execution, this will continually write data to your analogue output channel, also I wouls strongly reccomend that you use error handels within your code. The best approach would be to use the prebuilt examples as a template from which to build any new source file. The Multi Volt Updates-SW Timed is a good example of this.
01-24-2011 08:56 AM
Hi Andrew,
Thanks for the reply. Although I haven't included it in the code snippet above, my code is littered with error handlers hence I know everything is returning correctly.
You mention that I have to continously call DAQmxWriteAnalogueF64 to write data to the analogue output channel but I thought the whole point of regeneration was that you don't have to do that. Indeed my software actually works perfectly fine by just setting up for regeneration with a call to DAQmxSetWriteRegenMod(...). The voltage remains on the output indefinitely following a single write to DAQmxWriteAnalogueF64. The example you have mentioned (Multi Volt Updates-SW) is an example that uses DAQmxWriteAnalogScalarF64() to write single samples one at a time using a software loop. This is not what my code is achieving. Cont Gen Volt Wfm-Int Clk is the example my code is based on.
My question was and still is, why do I have to stop the task before writing a new value to the buffer before the next call to DAQmxWriteAnalogueF64?
Martin
01-24-2011 10:47 AM
Hey Martin,
Apologies I misinterpreted the question; however I believe I have found the answer to your question. When you want to change analogue output levels “on the fly” you should be setting up the output type in non-regeneration mode. This will continually poll the buffer for new data, whilst outputting the previous value. I have found an example which will demonstrate this for you.
Example:
http://zone.ni.com/devzone/cda/epd/p/id/1733
Let me know how you are getting along.
01-27-2011 10:23 AM
Hi Andrew,
Thanks for that, the example helped.
Cheers
Martin
